Discussion topic: Sky Q 2TB
This message was authored by: PrinceRoyston
Sky Q 2TB
Recently had a new 2TB to replace broken one, tv all good, but no apps have downloaded and unable to watch mini box upstairs as in settings these have a cross against them, has snybody hog any ideas please
Avatar for PrinceRoyston
Level 2 icon
Re: Sky Q 2TB
Sorry about spelling errors
Re: Sky Q 2TB
@PrinceRoyston for the apps you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
for the mini box in settings status watch on mini box where the X is scroll down to this then across to reactivate and press select
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Level 2 icon
Re: Sky Q 2TB
Hi
Thank for your suggestions, already tried this but made no difference, looks like I need to phone Sky and hopefully they can resolve it
