Discussion topic: Sky Q 2TB crashing
Message posted on 10 Oct 2024 02:03 PM
Sky Q 2TB crashing
Hi,
box worked fine for many years and started crashing two months back, usually from standby. sky sent a new (used) box which does the same thing. Left it running overnight to return to a frozen picture.
Is there an overarching issue with boxes currently?
Thanks,
Florian
Message posted on 10 Oct 2024 04:06 PM
Re: Sky Q 2TB crashing
Hi @drhex , what version of the Q box do you currently have?
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
Message posted on 10 Oct 2024 04:55 PM
HW is 32B12D
Message posted on 10 Oct 2024 05:38 PM
That's a 2nd generation box. The only one I had trouble with lockups was on a 1st gen box.
Might be worth checking the sat connections are are good and sat signal OK and that the box has the latest software. If you have any mini boxes make sure they are all on the same software version.
Message posted on 10 Oct 2024 06:02 PM
Did update the software on this one as well as the one mini I use. No change. Is it possible for the mini to crash the Q box? As I have another one on the shelf which I could swap in to see if that makes a difference?
Message posted on 10 Oct 2024 06:34 PM
Not sure but worth giving it a go
Message posted on 11 Oct 2024 02:25 PM
OK, will turn the mini off to see if that makes a difference first.
Message posted on 11 Oct 2024 03:42 PM
Hmmm, survived the night for once. Assume there is no way to get at the logs on the box?
