This discussion topic has been answered Discussion topic: Sky Mini box not working?
Message posted on 06 Mar 2025 04:08 PM
We have had a Sky Mini box installed with the aim of being able to use multiform. This was installed only 4 weeks ago The TV is now showing " no digital service is available ". The main TV in the lounge is working fine with Sky. We have tried ALL ways to correct the fault, but it still persists.
Would really like to speak to an individual and not a pre-recorded advice service. We are Diamond level customers and would appreciate the appropriate help and advice.
Thank you.
Message posted on 06 Mar 2025 05:13 PM
No need, Laing1. Managed to solve the problem!!! Scrolled through the screen options again and found out we needed to be on HDM1 !! Thanks for your kind help, No need to escalate now.
Message posted on 06 Mar 2025 04:35 PM
Re: Sky Mini box not working?
Thank you.
@Carousel2 that sounds as though its a message from your TV and not your Sky mini box. The TV maybe on the wrong input source .
If you find your TV remoteand with the sky mini box showing a green light use your tv remote to scroll through the sources until you see the picture from your mini box
Message posted on 06 Mar 2025 04:43 PM
Thanks Laing1. Tried that and it still does not work. Scrolled through all options and still nothing. When the engineer came out to fit the box initially, he had a devil of a job setting it up in the first place. They need to come out and sort it properly.
Message posted on 06 Mar 2025 04:58 PM
@Carousel2 I have escalated this to sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
