Discussion topic: Sky Mini Box
Message posted on 16 Aug 2024 04:50 PM
Sky Mini Box
Sky main box works ok but Sky Mini box does not work. The mini box screen is a blue saying no signal.
Message posted on 16 Aug 2024 06:16 PM
Re: Sky Mini Box
Hi @LizTaylor
Reboot the mini as above.
