2
This discussion topic has been answered Discussion topic: Sky Hd
This message was authored by: Neenar1970
Sky Hd
How can I cancel sky HD at £9 month? I don't use it? Thanks
Re: Sky Hd
@Neenar1970
To remove part of your TV package you need to contact Sky giving 31 days notice. If you have 'in contract' discounts you may not be able to remove them, because the discounts were provided on the understanding you’d be paying for the full period. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling using the number that should appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
Re: Sky Hd
@Neenar1970
Re: Sky Hd
When you say you don't use it, do you mean that you only watch the SD variants of each channel?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
