9
This discussion topic has been answered Discussion topic: Sky Engineer
This message was authored by: Johnandrews2024
Sky Engineer
I tried using an app to book a home move but it didn't do the check availability, the was a problem. I need to book an engineer
This message was authored by: Laing1 Answer
Re: Sky Engineer
@Johnandrews2024 have you tried the link below
https://www.sky.com/moving-home
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Sky Engineer
This message was authored by: Theo+Thomas
Re: Sky Engineer
Need to get the engineer to swap address from .y old address to new address
Engineering
Need the engineer to come to my new address  tomorrow
Re: Engineering
@Theo+Thomas
That's not going to happen unless it's been scheduled: posting here can't change any existing arrangements.
Heve you booked a Home Move or ordered a new service?
Re: Sky Engineer
@Theo+Thomas  Have  look at the post directly above yours
Re: Engineering
Well i Try book a home.move it wouldn't let me says we can't book home mov le
Re: Engineering
@Theo+Thomas  You'll need to call.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
This message was authored by: RosaLemes
Re: Sky Engineer
I tried using an app to book a home move but it didn't do the check availability, the was a problem. I need to book an engineer Help me please it's already a month old !
Re: Sky Engineer
@RosaLemes
If there's an issue you'll need to call. You can call free by dialling 150 from a Sky Talk landline or a Sky Mobile, otherwise you can use:
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible and don’t hang up.
