Discussion topic: Sky Dish not working
This message was authored by: P71
Hi my sky Dish is not working
Re: Sky Dish not working
@P71
Are you seeing an error message? Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
It’s not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Avatar for P71
Level 0 icon
Can someone please help me i need my sky Dish fixed
@P71
Please read the reply already provided.
Edit: your duplicate post on another thread has been removed.
