06 Feb 2025 01:25 PM
Good afternoon,
Trying to troubleshoot a problem and work it whether it's the Sky Dish, Sky Q Box or TV Problem. I've turned off the power to the Sky Q box, checked all leads from Q box to TV and turned back on power but problem still persists.
If you are able to play the attached video clip you will see what I mean. At bottom of the screen there's a horizontal bar appeared with loads on lines across it.
My thoughts are if it was the dish the distortion would be all over the screen. It could be the box but I think it's maybe the TV starting to go and breaking down.
Anyone experienced something simular and have any thoughts ?
TIA
06 Feb 2025 01:38 PM
Posted by a Superuser, not a Sky employee. Find out morehi @F60Mini
Definitely not the dish.
Could be the TV, Q box or possibly the cable
Can you try plugging into a different HDMI input on the TV ?
Do you also have a different HDMI cable to try ? Although my guess this is the unlikely cuplrit in this case
06 Feb 2025 01:52 PM
Thanks for your reply. I did try a different HDMI port but made no difference.
I'll get another cable at weekend and also see if I can borrow a TV off a neighbour.
Thanks again.
