Discussion topic: Sky Box.
Message posted on 12 Sep 2024 06:58 PM
Sky Box.
Having a problem with my sky box. The light is showing amber. Can't get it to change to green when I press the sky button on my remote. So that I can then access service.
Message posted on 12 Sep 2024 06:59 PM
Re: Sky Box.
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 12 Sep 2024 07:02 PM
Re: Sky Box.
I have tried pressing the button on the front of the sky box, but it remains Amber. This suggests to me that there is not a problem with the remote, but with the sky box.
Message posted on 12 Sep 2024 07:04 PM
Re: Sky Box.
The sky box I have is quite an old one. It just says sky on the front left.
Re: Sky Box.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 12 Sep 2024 07:06 PM
Re: Sky Box.
That's the same as all the main Q boxes @RogerMacNair
