Discussion topic: Sky Box turns off
This message was authored by: ElenM
Sky Box turns off
I see this is a common problem but I can't find any solutions that have reliably worked for people.  Sky also don't put a phone number anywhere obvious to get in touch so I hope that people here can help.
Our Sky box randomly turns off.  It has done infrequently since we got it.  I cannot find a cause and I have even got it set on a wired connection now.  Turning it on and off doesn't help.
Has anyone actually fixed this and if not, what is the Sky phone number to get in touch with a human being?
Re: Sky Box turns off
Hi @ElenM
As far as contacting Sky
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Avatar for ElenM
Thanks!
I will try this now.
Avatar for ElenM
Still turning off.
I guess that doesn't work.
Any other ideas?
hi @ElenM
When it switches off does the screen shrink & possibly bounce around  ?
Avatar for ElenM
No, the screen goes black and the power light turns red.
Theres no small screen showing.
This message was authored by: DisplayName2000
Try changing the standby settings
https://www.sky.com/help/articles/using-the-standby-settings
or check for minor electrical fails on your grid.
Sky wants to decrease the load on their call centers, but on the end of most articles there is a phone number.
Avatar for ElenM
I've plugged the box into another socket although the previous 3 Sky boxes have been happy there.
I looked at standby settings but it's powering off, not going to standby, and it's set to eco.
The box still went off 3 times this evening.
