Discussion topic: Sky Box Red Light
Message posted on 05 Oct 2023 08:32 AM
Sky Box Red Light
Sky box won't turn on, light constantly red. Tried resetting, unplugging, changing battery remote......either goes off completely or just shoes red light
Message posted on 05 Oct 2023 09:57 AM
Re: Sky Box Red Light
Hi @JFW13
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
