Discussion topic: Sky box not turning on
This message was authored by: Sarah09
Message posted on 05 Oct 2023 08:29 AM
Find out more
Message posted on 05 Oct 2023 09:59 AM
Re: Sky box not turning on
Hi @Sarah09
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
