Discussion topic: Sky Atlantic
This message was authored by: Russ777
Sky Atlantic
I can not get the program sweetheart to play
Re: Sky Atlantic
@Russ777 Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
