17 May 2024 07:45 PM
Cannot access sky Atlantic SD. Do not have HD ad on - dropped it to save money. SD should be available on channel 808 but shows as HD. Have set download default to sd
17 May 2024 07:47 PM
Have you checked channel 108?
17 May 2024 07:52 PM - last edited: 17 May 2024 07:53 PM
If you do not have the HD add on then all the SD channels will take preference in the guide listings.
Free to air HD will also take preference.
17 May 2024 08:23 PM
108 is marked as HD. If I select I an not subscribe message
17 May 2024 08:25 PM
Posted by a Superuser, not a Sky employee. Find out morePerhaps try rebooting the box then check the epg again.
~ press the 🏠 button
17 May 2024 08:26 PM
Sorry last post should have read - if I select I get an upgrade required message. Applies to 108 and 808
17 May 2024 08:29 PM
Thanks will try another reboot following your instruction carefully
18 May 2024 06:03 PM
I tried a reboot s suggested but it has not resolved the issue. Sky Atlantic HD is on channel 108. Sky Atlantic SD is supposed to be on 808 - but is listed as HD. Both give an upgrade message. I did drop my HD add on (cost saving) but am baffled as to why I cannot access the SD version. This also effects sky docs & sky arts. Any other ideas or is this a subscription issue rather than a technical glitch.
18 May 2024 09:40 PM
@BobDerbyshire You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
