Discussion topic: Sky Atlantic SD
This message was authored by: BobDerbyshire
Sky Atlantic SD
Cannot access sky Atlantic SD. Do not have HD ad on - dropped it to save money. SD should be available on channel 808 but shows as HD. Have set download default to sd
Re: Sky Atlantic SD
@BobDerbyshire
Have you checked channel 108?
Re: Sky Atlantic SD
Hi @BobDerbyshire
If you do not have the HD add on then all the SD channels will take preference in the guide listings.
Free to air HD will also take preference.
Avatar for BobDerbyshire
Re: Sky Atlantic SD
108 is marked as HD. If I select I an not subscribe message
Re: Sky Atlantic SD
@BobDerbyshire
Perhaps try rebooting the box then check the epg again.
~ press the 🏠 button
Re: Sky Atlantic SD
Sorry last post should have read - if I select I get an upgrade required message. Applies to 108 and 808
Re: Sky Atlantic SD
Thanks will try another reboot following your instruction carefully
Re: Sky Atlantic SD
I tried a reboot s suggested but it has not resolved the issue. Sky Atlantic HD is on channel 108. Sky Atlantic SD is supposed to be on 808 - but is listed as HD. Both give an upgrade message. I did drop my HD add on (cost saving) but am baffled as to why I cannot access the SD version. This also effects sky docs & sky arts. Any other ideas or is this a subscription issue rather than a technical glitch.
Re: Sky Atlantic SD
@BobDerbyshire You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
