Discussion topic: Sky 1 problem watching recorded programs
This message was authored by: helen172
Having problems watching sky 1 recorded programs  , telling me to upgrade , but can watch live ??
Re: Sky 1 problem watching recorded programs
hi @helen172
Are they downloads rather than recordings.
if downloads then:
As the default download quality is set to HD (high Definition) not SD then if you do not have the HD add on then when you try to download and watch you may be  prompted to upgrade (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
