Discussion topic: Skq was not installed as engineer had problem with communal dish and feedback
This message was authored by Neely This message was authored by: Neely
Sky communal ariel has block init and no one will help to remove said block i.e building factors so should i just go with sky stream instead
This message was authored by Godfrey This message was authored by: Godfrey
Re: Skq was not installed as engineer had problem with communal dish and feedback
Could you expand on what you mean by the term 'block'
Godfrey.
Neely
Sky wngineer was trying to install q box and he said the signal was blocked and he only recieved feedback leading him to believe there is some sort of block on the communal ariel i have no idea or getting anywhere with building factors to resolve the issue wich is frustrating
This message was authored by Chodley This message was authored by: Chodley
Aerial or dish?
Assuming dish - do you mean it works with older Sky services but not Q?
