Discussion topic: Skq q
This message was authored by: Tinkerbell26
Skq q
Hi, I have an engineer coming out tomorrow to install sky q and a multi screen, the sky dish i have is old, not sure exactly, as I've been at the address 11 years but dish was up way before I moved in, anyway the cable/s have been cut,. Will the engineer replace them?
Re: Skq q
@Tinkerbell26
Yes. Any damaged cabling will be replaced and so will the dish if it needs to be.
Avatar for Tinkerbell26
Re: Skq q
That's great thank you
