Discussion topic: Since installing Sky Max the mini box keeps losing the network
This message was authored by: Jason+Carl
I recently moved to Sky Max. Since then the mini box keeps dropping the network. Spoke to the help desk and tried all their suggestions; from eco mode to active, reducing disk space, etc. And was sent a range extender. None of which worked.
An engineer was booked but the day before the main box network connection failed and on restoring it the mini box seemed stable. Roll forward a day and that is failing again.
Help!
Re: Since installing Sky Max the mini box keeps losing the network
Help!
Hi @Jason+Carl
Try a complete reset as follows.
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
I)n Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
once the main Q box is connected and fully running and then reboot the mini.
Have you tried rebooting your Q box?
To reboot press Standby on your Sky mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your Sky mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini Q remote or if this is not working press the standby button on the front of the mini box (Amber led).
note: some features may take up to 5 minutes to
If the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
Avatar for Jason+Carl
Thanks, I don't think there is a reset button on the Sky Max router? I have turned it (and everything else) off and on and reset connections but no change to the problem. And already have the Sky Max Wi-Fi booster but also no change.
