Discussion topic: Signature package channels not available
This message was authored by: DiTom1
All these channels have no signal or picture is affected so you cannot watch. 104,106,107,108,113,114,122,123,124,129,130,132,135,143,145 I stopped at 145 there are probably many more?
Re: Signature package channels not available
@DiTom1
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
