Discussion topic: Signature Package
Message posted on 19 Sep 2024 02:32 PM
Signature Package
I can't believe the trouble I have had to go through to get a simple question answered. With the signature package, can I watch the History channels, I can on my mobile, but the TV keeps telling me I need to upgrade to watch it?
Message posted on 19 Sep 2024 02:34 PM - last edited: 19 Sep 2024 02:35 PM
Re: Signature Package
Are you trying to watch the HD channel without a HD sub?
Try channel 821
Message posted on 19 Sep 2024 02:39 PM
hi @TonyJ1
if you are downloading the show & if you don;t have the HD add on then:
As the default download quality is set to HD (high Definition) not SD then when you try to download and watch you are prompted to upgrade (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
No idea pal, I have tried via the MY5, and catch up with no avail, I'll give that a go.
Thank you.
Message posted on 19 Sep 2024 02:40 PM
Hmm, I'll try that too, thank you.
Message posted on 19 Sep 2024 02:46 PM
Message posted on 19 Sep 2024 03:57 PM
Thanks again.
