Discussion topic: Signal
This message was authored by: nessnor
Signal
After the outage ours is still cutting off and saying currently affected
Re: Signal
What signal and what has this to do with accessibility?
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
Re: Signal
@nessnor
The outage only affected Sky Q so presume you have that TV platform.
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
