Discussion topic: Signal
This message was authored by: Batty4
Signal
No satellite signal this morning. Recordings not even available can anybody help . Also broadband router is working fine . Can anybody help please .it was working fine last night
Re: Signal
@Batty4
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for Batty4
Recording
After no satellite signal yesterday problems which is now sorted .all my recordings have gone 🤷🏻‍♂️. How can I get them back or are they gone forever thanks
Re: Recording
@Batty4
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
