Discussion topic: Signal
This message was authored by: Declan3
Signal
No signal
Re: Signal
@Declan3
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
