Discussion topic: Signal on mainstream tv freezes regularly.
Message posted on 27 Feb 2024 09:46 AM
Tv signal on 2 sky q boxes freezes regularly. I have switched off and unplugged all sky tv equipment and restarted one by one. This has not solved the problem. The main sky q box is not affected, just the 2 remote boxes.
Message posted on 27 Feb 2024 09:57 AM
							Re: Signal on mainstream tv freezes regularly.
Hi @John238
Try a Network Reset on the minis.   Start with the one nearest to the main Q box.  If you are on Sky Broadband and the router is nearer to a mini then the main box start with that one
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box or router.
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis  and you will need to contact Sky directly.
