Discussion topic: Signal damaged lost channels
This message was authored by: Carrie21
For months now lost quiet alot of channels and its said there signal damaged
Can watch any channel so what point paying for sky these days
Re: Signal damaged lost channels
@Carrie21
I'm not aware of a message saying signal damaged.
If you’re seeing a message displaying ”No signal” it tends to be from your TV, such as possibly not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Whenever a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company who deal directly with their approved engineers.
