Discussion topic: Should I change to Sky stream?
This message was authored by: robert_h
I have Sky Q with 4 Sky Q Mini Boxes and 2 of the mini boxes regularly loose connectivity in one way or another so should i be considering changing to Sky Stream ? In which case how many Pucks can i get on one account.?
This message was authored by: Tina1961
Re: Should I change to Sky stream?
I would absolutely avoid it at all costs.
Its an apalling product but then its to be expected from Sky.
Stick to Q if you can, especially as they are continuing to supply it for now.
I am going to try and return my Streams and go back to Q.
@robert_h I believe you can have 6 Pucks. But if you're issue with Sky Q is boxes dropping connection, is switching to a system completely reliant on a fast and stable connection the right thing to do?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
