Discussion topic: Setup tv controls on 2nd remote without paring
Message posted on 09 Sep 2023 01:14 PM
I got a 2nd sky q remote ( new with blue voice control button ) But I am unable to pair it with my sky Q box. * even after using 7 + 9 to unpair first remote
THis isn't really a problem as it controls the Sky BOX fine. ( and original remote can be paired )
However I wantto setup tv controls on the new remote
Is there a way to setup tv control without pairing ?
Message posted on 09 Sep 2023 01:19 PM - last edited: 09 Sep 2023 01:20 PM
Re: Setup tv controls on 2nd remote without paring
Hi @gwvc
Pair a remote to the Q box and the TV in the normal manner (by pressing 1 & 3 together) and then pair to TV.
You can press 4 & 6 together which will unpair it from the Q box.
You will then need to pair another Bluetooth remote to the Q box
