8
This discussion topic has been answered Discussion topic: Settings altered
This message was authored by: Ladytoad
Settings altered
Watching Tele on channel 4 ,then the picture just went dark,is this due to using less electricity at times they don't want you to use .I'm finding it hard now to watch my TV in comfort because brightness altered yet cannot find how to bring it back.bad for everyone's eyes it's a strain .so sky what have you done and bring my Tele back to normal .
Avatar for Ladytoad
Level 2 icon
This message was authored by: Ladytoad Answer
Re: Settings altered
Got it sorted now .thanks anyway .
@Ladytoad
It's nothing Sky has done or do to conserve energy.
By the way you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
What Sky TV platform do you subscribe to?
Avatar for Ladytoad
Level 2 icon
I get all my services from sky .
Please answer the following question so that your thread can be moved to the correct place, where you're more likely to get help with your query
Which Sky TV Service do you have?
Sky Plus (Satellite box)
Sky Q (Satellite box)
Sky Glass (Internet TV)
Sky Stream (Internet box)
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
@Ladytoad
Do you have Sky Q, Sky Glass or Sky Stream ?
Avatar for Ladytoad
Level 2 icon
No I only have a normal TV ,but thankyou for your help .
Avatar for Ladytoad
Level 2 icon
No I have a normal TV ,sky  Q  thankyou got your help .
Sky Q doesn't have any settings that dim the picture. What make/model is your TV? It's likely to be a setting on the TV itself as they all have energy saving modes these days which may have been inadvertently switched on.
Avatar for Ladytoad
Level 2 icon
Answered - Go to Answer
