1
This discussion topic has been answered Discussion topic: Set up sky q mini but when clse kitchen door it doesnt work
This message was authored by: De7
The sky mini box has been set up but when I close the kitchen and front door door it doesn't work. Is there such a thing as a booster that could help?
Re: Set up sky q mini but when clse kitchen door it doesnt work
Hi @De7
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Hi @De7
