Discussion topic: Set up fee for extra mini box
This message was authored by: Louise394
Hello. I am interested in getting another additional mini box. I understand there is a monthly charge for this but I would really rather not pay the £50 set up fee. I have been a Sky customer for many years and I wondered if there was a possibility that this set up fee could be waived please? Kind regards Louise
Re: Set up fee for extra mini box
@Louise394 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
you would need to speak to Sky
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Louise394
In case you aren't aware you can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
As it appears you have multi screen already then there wouldn't be an additional monthly charge.  (Just the one off charge which is unlikely Sky will waive - but don't ask, don't get)
