7
This discussion topic has been answered Discussion topic: Set BBC region
This message was authored by: stevengandpata
Set BBC region
My Sky Q box went down and had to reset the connections. I have since lost my local BBC channel. I went into settings and could add ITV to my region. How can I add Yorkshire
Avatar for stevengandpata
This message was authored by: stevengandpata Answer
Re: Set BBC region
Hi all
setting BBC local under favourites worked and before I contacted Sky the local BBC came back on its own 🤷
thsnkyou for all your help👍
Re: Set BBC region
Channel 101 should be your local channel (set by account postcode).
Re: Set BBC region
Hi @stevengandpata   That's quite novel, how did you manage that? I wasn't aware that there was any region settings in Sky Q apart from all the regional channels in the 800s.
Re: Set BBC region
For ITV I went to Media Mole page and they give the information on regional channels and how to add them through settings menu
Re: Set BBC region
101 use to be my local channel but since my Sky W needed resetting I now have a Southern channel and not Yorkshire
Re: Set BBC region
Ok, then you cannot change that.
What you can do is set up favourites where 1 is your correct region.
Re: Set BBC region
Hi
101 use to be my local BBC but not anymore. I think I will have to try and ring Sky
Re: Set BBC region
Hi all
