Discussion topic: Series links
This message was authored by: Aethelflaed
Series links
Can I set a series link to record only new series? Currently it records reruns as well.
Re: Series links
hi @Aethelflaed
Unfortunately there are no separate settings for Series Links - the links work with whatever episodes/series thr broadcaster sets them for.
Generally they do only record a specific series - if you feel it is set for more than it should then probably best to email Viewer Relations : viewerR@Sky.uk
(make sure you specify which programme & which channel you are setting & mention the other series you are not expecting)
