Discussion topic: Second sky tv box
Message posted on 19 Aug 2023 06:09 PM
Second sky tv box
I have got a second sky box that won't connect to the TV
i keep having to unplug and plug again and even then it won't sometimes. The remote keeps freezing randomly
Really annoying issues that have been going on for so long. It's so difficult to get an engineer to come.
Message posted on 19 Aug 2023 06:20 PM
Re: Second sky tv box
I take it this is a Sky Q mini box sourced from Sky. Was it set up by Sky and has it ever worked properly?
Message posted on 19 Aug 2023 07:52 PM
Hi @Nislam
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
