Discussion topic: Second box remote doesn’t work
This message was authored by: Magnus2
Hi,
My second box remote has stopped working
can you lease send me a replacement as soon as possible.
thank you
Magnus
Re: Second box remote doesn’t work
Hi @Magnus2   Unfortunately you are not talking to Sky here. Please see Welcome below for information about this community. However this help page should lead you to requesting a replacement remote.
https://www.sky.com/help/articles/sky-q-remote-help
@Magnus2 wrote:
Hi,
thank you
Magnus
hi @Magnus2
Have you tried a reset of your remote ?
If not please, may I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
