12 Jun 2024 01:19 PM
I haven't been able to use sky search function for about seven days now, can't get it using information on the same problem in 2022......anyone know how to get it going ?
12 Jun 2024 01:41 PM
hi @Widdeboy
Is that both the Voice search & the manual search using the Magnifying glass Key & remote keypad ?
What error message or behaviour are you getting ?
Voice search needs the remote to be working in bluetooth mode & and the box to have an active internet connection
The first thing I suggest is to restart your SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
12 Jun 2024 03:32 PM
Tried all you suggest, I get no message at all , just no response to the search button on the remote.
12 Jun 2024 04:07 PM
Hi @Widdeboy
