Discussion topic: Screen not appearing HDCP
This message was authored by: SusannahBarratt
Hello my sky won't turn on,
it displays the message "this screen for not support HDCP. Try connecting your HDM cable or use a different screen"
Re: Screen not appearing HDCP
Hi @SusannahBarratt
Remove both ends of the HDMI cable between the Q box and the TV.
And then refit it.
See if that corrects it.
This message was authored by: ThePope27
@SusannahBarratt,
Are you using the Sky provided HDMI cable or your own,
If it's the latter I recommend changing it to the sky supplied one.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
