Discussion topic: Screen keeps going off on sky q box
This message was authored by: John0611
Sometimes I loose sound and others the screen goes blank for a couple of seconds then back on
Re: Screen keeps going off on sky q box
Hi @John0611
Avatar for John0611
Thank you resetting the settings sorted the problem thank you for help received
