Discussion topic: Satellite signal
This message was authored by: Lewismatt2
Satellite signal
How do I fix satellite signal ?
Re: Satellite signal
@Lewismatt2
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
