Discussion topic: Satellite dish
Avatar for Rhian1239
This message was authored by: Rhian1239
Re: Satellite dish
Thank you, looks like I need to switch to stream! Thank you so much!!
Re: Satellite dish
hi @Rhian1239
As the others have said the box you had installed does not affect the Satellite Signal itself
I suspect somehow, during the install of the new box your SKY Q Satellite box has been disturbed and possibly the connections knocked.
Can you check  that   the cables at the back are properly connected
Re: Satellite dish
Well you don't NEED to. Nothing to stop you carrying on using Q and Stream is quite a different experience.
Re: Satellite dish
No this does not mean that  you need to switch to Stream
Re: Satellite dish
@nigea99 wrote:
hi @Rhian1239
The OP disconnected them.
Re: Satellite dish
@TimmyBGood wrote:
@Chodley wrote:
some installer didn't just show up and connect this up on a whim?
I wish they'd done a better job with the ONT location, and that fibre is cut awfully brief...
Agreed. I wouldn't want my fibre being subjected to that.
Re: Satellite dish
@Chodley wrote:
@nigea99 wrote:
hi @Rhian1239
Sorry I missed that
@Rhian1239  you need to reconnect the cables from the dish - ensure that they are both connected and tight.
Re: Satellite dish
Just reconnect the Two dish cables to the Q box @Rhian1239
Just take care not to bend the central copper conductor in the two F connectors.
'Once it is connected back up reboot your Q box.
