Discussion topic: Satellite dish
This message was authored by: Karlie2
Satellite dish
How do you go about replacing a satellite dish?
Re: Satellite dish
@Karlie2  Do you have Sky+HD or Sky Q?  Why do you think your dish needs replacing?
This message was authored by: nolte
Re: Satellite dish
@Karlie2
Is this sky q or sky+hd?
Are there any error messaging appearing on screen or problems with reception on channels?
ROI sky Q Customer.
Avatar for Karlie2
Re: Satellite dish
It has got extremly rusty and bits are starting to fall off and the rust is staining the wall.
Re: Satellite dish
@Karlie2
You need to tell us Sky+ or Sky Q as our advice will be different depending on which you have.
Avatar for Karlie2
Re: Satellite dish
I have SkyQ
Re: Satellite dish
@Karlie2
The ownership of the dish and associated cables transfer to the householder on installation.
Give Sky a call. They would usually replace it if parts are falling off it. Note that you are responsible for any damage or injury this causes not Sky.
Avatar for Karlie2
Re: Satellite dish
Its at the back of the house so won't cause an injury. I can't seem to find a number to call someone at SKY.
Re: Satellite dish
@Karlie2
Call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn't allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka 'the bot') which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
Avatar for Karlie2
Re: Satellite dish
Unfortunately,  I dont have a sky mobile or landline.
This message was authored by: Me134
Re: Satellite dish
Then you'd have to google the 033 number I'm afraid.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Re: Satellite dish
Get the correct number from Sky's help pages.  Googling numbers can have some risk.
Re: Satellite dish
@Karlie2   These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
