Discussion topic: Satellite connection
This message was authored by: Victoria+McCormic
Turned on sky box's this morning, the sky box isn't showing channels, no satellite. Q box and everything has tick connection. But every time you click a channel a message comes up. Worked fine yesterday. Turned hub on and off and online procedures done but no improvement and can't find a number to contact you. We pay for a good service as we just moved from virgin but now it feels impossible to get through to anyone. Can you help please?
Thanks,
Vic
Re: Satellite connection
@Victoria+McCormic
There will be no automatic contact from Sky due to you posting on here as this is primarily a customer helps customer forum and you’re not talking to Sky Customer Services.
Have a look at this link
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
but you may end up needing to arrange an engineer to check your dish isn't out of alignment.
This message was authored by: Invisiblename
@JordanBGoblin wrote:
If the dish or cables are damaged, your only option is the management of the building or the Sky engineers. Sky engineers can't touch the dish and power splitter if its managed by your building.
At what point did the OP say that it was a communial dish?
I am just another Sky customer!
Where the if and or part invisible or are you just trying to make me look bad?
No, but then I've no idea what you're trying to say here, either.  But I stand by what I said, I can see no reference to the OP saying that they were on a communal / shared dish.  If they own the property & hence the dish along with the cables from it, Sky or an independent can be arranged to look at them.
@JordanBGoblin
In fairness I too was wondering where you had got that possibility from and read the OPs post a couple of times to check.
https://www.sky.com/help/articles/how-to-make-a-complaint
What is the relevance of your post?
This message was authored by: JordanBGoblin
It shows how to contact sky.
Repairing TV, broadband and computer devices from 20 years in the UK, Czech Republic, Eastern Europe.
@JordanBGoblin but that gives the op the number to make a complaint which is a different number for problems they would need to do the  following
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
