Discussion topic: Satelite Signal
This message was authored by: Cheekey
Satelite Signal
Hi, I am having a problem with the Sky TV satellite signal lost. I tried to reboot twice but it has continued with the same problem.does any one know what could go wrong. Is it something to do with weather or the communal area signal lost ?
Let me know thanks..
Re: Satelite Signal
Hi @Cheekey
If you do not have your own Dish and are on a Communal system then check with your neighbours if they have the same issue.
If you are on a Communal system check in in your Q box Home - Settings - Status - Satellite signal.
LNB type should say SCR (and not Wideband)
