Discussion topic: Remote
This message was authored by: Lottie08
Message posted on 14 Aug 2023 07:35 PM
Remote
Remote control doesn't work on the additional sky box
Find out more
Message posted on 14 Aug 2023 07:38 PM
Re: Remote
Hi @Lottie08
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
