Discussion topic: SQY Q Box does not remember BT wifi password
This message was authored by: Daveydee
I've had to switch to a Wi-Fi connection to my Sky Q box.   It seems that Sky Q box does not remember the password for my BT wifi.   It's such a painfully slow method for selecting all the letters and numbers to enter.   So it's so annoying to find the following day I have to do the same again.   I note that this subject has been raised a number of times before .
Re: SQY Q Box does not remember BT wifi password
Any 5GHz steering enabled?
Have you disabled BT Smart connect?
This message was authored by: bob1234
It is always a good idea to disable "smart" although if you have a smarthub2 BT don't make it easy for you. Instructions at the bottom of this post.
I had a V2 box, the one with the separate power unit, and this always gave me problems with passwords. In the end I used a powerline LAN extender, this fooled it into thinking it was connected by Ethernet and never needed a password again.
To turn off smart.
If you log on as admin enter the password then open another browser tag and use this link http://192.168.1.254/smart_setup.htm
You can turn it on/off there.
Another example of BT's staggering incompetency
Avatar for Daveydee
Thanks for replies but my BT Snart Hub 2 does not show smart.   I believe that the latest firmware has it removed
@DaveydeeHow to do it is in my post above yours.
Avatar for Daveydee
Tried your suggestion but it takes me to router dashboard but that's it
This message was authored by: Invisiblename
Go to 'Advanced Settings' / Wireless / Channels, then select a non-Smart channel
ignore this, follow @bob1234 's guide - works for me from my iPad
I am just another Sky customer!
@DaveydeeOnce you have the dashboard open in advanced settings you need to open another tab using the link I gave. I have just tried this from a PC and it worked.
Did you use your admin password to get into advanced settings. Once you are in the hub go into wireless or similar and use your password then the link I gave. I have posted a screen shot, it needs approval before it shows.
