Discussion topic: SKY Q
Message posted on 11 Jul 2026 01:24 PM
SKY Q
I have been updated to SKY Q from my SKY+ system.
I receive WI-FI okay up to now but I cannot access my socket plugged in computer. Is it because I need Fibre installed as well . An engineer is wishing to come and install Fibre. No idea if it is Part of Full Fibre.
Message posted on 11 Jul 2026 04:36 PM
Re: SKY Q
Do you currently have broadband? If yes then you just need to go into the Q box's network settings & add the SSID & Passcode from the router, if you have Sky broadband then you can also use WPS button on both the router & Q box to set up internet on the box.
The Sky Q box connects to a satellite to receive channels so WiFi is only required to access third party apps & possibly box updates.
I don’t work for Sky.
If I have helped then please leave a like.
