Discussion topic: SKY Q showing wrong network when wired.
Message posted on 30 Aug 2023 11:14 AM
Hi I have a strange issue where my sky Q box is advertising what looks like a neighbours WIFI as connected even though it's connected to my router via ethernet! the mini Q box also shows the same SSID.. any ideas!?
Message posted on 30 Aug 2023 11:27 AM
Re: SKY Q showing wrong network when wired.
It will be the name of your Sky's internal mesh network that links the main and mini boxes.
Message posted on 30 Aug 2023 11:48 AM
@TonyLo Who is your broadband provider ? Is the mini connected by wifi or ethernet ?
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Message posted on 30 Aug 2023 11:52 AM
Hi provider is Vodafone when connected via WiFi it shows the Vodafone said but when hard wired it shows a sky SSID
mini box is connected via WiFi atm until I run the cable
Message posted on 30 Aug 2023 12:55 PM
@TonyLo right so when connecting a mini box to the main box by wifi the Main box emits a Sky mesh that the mini box joins(it doesn't use your vodaphone wifi) this is what you are probably seeing and as you are using the mini by wifi it is more than likely just showing this as the ethernet connection as well due to the mesh being enabled.
Message posted on 31 Aug 2023 01:19 PM
I have both on a wired connection now both plugged directly into my Vodafone modem and they are both still showing as a sky network.
when I then went to put the TV on WiFi the same sky WIFI Id appears (also on a mobile) but asks for a password when you try to connect?
does this seem normal still?
Message posted on 21 Jan 2024 06:45 PM
I have exactly the same problem have had Sky Q for a year and suddenly it is showing I'm not connected to the internet which isn't the case
when looking at settings my neighbours sky broadband is coming up My provider is bt very odd
Message posted on 10 Jul 2024 10:52 AM
Hello, just wanted to confirm I've got the same issue.
Long story short, recently changed network provider as full fibre became available in my area and I've had issues with it that's caused me to reset the router settings multiple times.
I noticed one of my mini boxes claimed its network SSID was my old router, which is unplugged.
When I checked the main box, I found it thought the same, so I reset it. Once reset, I opted for Ethernet and it refuses to acknowledge the name of my new SSID. It instead refers to the network as one of the Sky box ID's. I even unplugged all of the mini boxes just in case it was picking up something from them but I get the same result. Even stranger is that the box DOES act as though its connected yet my router tells me the Sky isn't connected and I can't find the matching MAC address. Utterly bizarre and I'm baffled.
One last thing I forogt to note, I do have the option of manually selecting my new router via WiFi of course and this does show up correctly.
Message posted on 29 Jul 2024 12:12 PM
Similar problem for me. Recently changed my broadband provider from Vodafone to Plusnet and connected through ethernet but it's showing a Sky SSID.
Done the network reset and it's made no difference. I only have the Sky Q box though, no mini boxes or anything similar.
The fact I'm connected through WiFi on other devices but it's showing this on a wired connection is a concern. Given that I don't have any other boxes apart from the main Sky Q box I can't imagine it is a sky mesh ID.
Advice is appreciated but seems a common fault. If it is how it is, I'll leave it
Message posted on 29 Jul 2024 01:12 PM - last edited: 29 Jul 2024 01:15 PM
Hi @DugdaleLynch1994 If it is a fault then it is an 8 year old fault. There is only one thing that matters, it works! As an example, mine is showing the BTHub6 name from 5 years ago. I am using Gigaclear Linksys router now, and had a BT SH2 before that.
Message posted on 13 Sep 2024 08:28 AM
Hi All,
currently facing the same issue, My current broadband supplier is See The Light a sister company to Sky. They only provide you with a basic TP link router but when connecting my Sky Q box to it the box maps is with a Sky router SSID and says it's connected to the internet but I cannot use any of the on demand services.
Ive logged onto the router and can see no IP address assigned to the port with Sky Q box. In speaking with my BB supplier they believe this to be a Sky issues. Has anyone else had this before?
Message posted on 13 Sep 2024 09:03 AM
If it's connected over ethernet, have you disabled wifi?
does the Q think it's been assigned an IP address?
Message posted on 13 Sep 2024 09:08 AM
I have disabled the WiFi, I've tried connecting to the router via WiFi and it still assigns the wrong SSID
Message posted on 13 Sep 2024 09:22 AM
The ssid issue is a red herring but the fact it can't access content is odd.
Message posted on 13 Sep 2024 10:38 AM
Yeah I'm stuck in what to do, I have been waiting for a engineering appointment to be given to me as the engineer left we with this service when it was installed last week.
slightly annoying.
