Discussion topic: SKY Q not working
This message was authored by: js123js
SKY Q not working
Sky q box not working. Have updated software, hard reset the box. Intermittent select channels, but 1 minute delay in switching channels. Can watch for short period then freezes and needs to be reset.
Re: SKY Q not working
 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for js123js
Hi... thanks for response but yes I've gone through the 001 menu and used 'all' resets, with no joy. Im 99% surenits the hard drive as some of the sounds are similar to a PC drive thats skipping. I booked an engineers visit but two weeks before a visit with no TV in the meantime! Not much of a service for a customer of 25 years! Thanks again though for you thoughts  🙂
Tenure has no baring on engineer availability i'm afraid, you will have been given the earliest available slot.
