Discussion topic: SKY Q Satellite Signal/Quality Question
Message posted on 30 Dec 2024 01:13 PM
Hi all just a random question but when I got my Sky Q installed a few months ago I was getting 70 Signal 90 Quality but now since the bad weather we have had it's gone down to 60/90? Is this still good enough clearly the Quality is more important? Just enquiring to see if I need to contact sky due to a possible dish move? Also I'm guessing the Q box wouldn't give a 100% Accurate reading thanks 🙂
Message posted on 30 Dec 2024 01:28 PM
Re: SKY Q Satellite Signal/Quality Question
@MrKieranb wrote:Hi all just a random question but when I got my Sky Q installed a few months ago I was getting 70 Signal 90 Quality but now since the bad weather we have had it's gone down to 60/90? Is this still good enough clearly the Quality is more important? Just enquiring to see if I need to contact sky due to a possible dish move? Also I'm guessing the Q box wouldn't give a 100% Accurate reading thanks 🙂
@MrKieranb unless you have difficulty finding some channels or picture breakup on channels, I wouldn't worry about those readings.
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 30 Dec 2024 01:37 PM
UHD Sports channels SD and HD seem ok 🙂 brilliant thanks for clearing that up 👍
Message posted on 30 Dec 2024 01:38 PM
@Doc5907 UHD Sports channels SD and HD seem ok 🙂 brilliant thanks for clearing that up 👍
