Discussion topic: SKY Q - Minibox
Message posted on 19 Apr 2025 12:00 PM
SKY Q - Minibox
How many SKY Q miniboxes can be used at the same time
Message posted on 19 Apr 2025 12:13 PM - last edited: 19 Apr 2025 12:14 PM
Re: SKY Q - Minibox
@KishPatel wrote:How many SKY Q miniboxes can be used at the same time
To watch live Tv, 2 + the main Q box.
If you have the original (non UHD) 1TB box, you can only watch on 1 mini at a time.
You might be able to watch on a third box if one of the others are being used to watch through apps.
Message posted on 19 Apr 2025 01:20 PM
Re: SKY Q - Minibox
@KishPatel You can have a maximum of 4 mini boxes loaned to you by Sky.
All 2TB boxes and the UHD/HDR 1TB permit watching on two mini boxes and the main box at the same time. You may also be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
The older 1TB non UHD box only allows you to watch on 1 mini box as well as the main box .
Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
